Hi all,
This summer I switched to a OnePlus7, and overall I've been happy with it. However, the main issue I have with the phone is the lack of a 3.5mm port. I have gone through a converter more than once per month since I got the phone.
Obviously, it goes through very heavy use, I'd estimate maybe 5 or more hours per day. I do not bend the cables in small radiuses, or rip them out of their socket from the cable, although it is used while running/cycling, and this could contribute to wear.
The headphones I use are very expensive and I'd really rather not switch if possible.
Instead i'd like to ask for recommendations from you guys. I'm wondering if for example the problem is the flex in the cables on the connectors. Perhaps a rigid one would last longer?
