Putting together my first rig and was offered the idea of a heat sink over just the stock cpu cooler. was wondering if more experienced people can help me answer the question of what is a good choice for a heat sink that will easily fit in my case. will be doing some oc'ing. heat sink budget more or less $50.00
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
ASUS P7P55D-E Pro LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621
Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I5750
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-2G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409
COOLER MASTER Intel Core i5 compatible GeminII S RR-CCH-PBU1-GP 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
this is the heat sink i am looking at right now, if there is a better one for the price please share.
