I'm building a low-cost system and wanted to get a few opinions before I pull the trigger and order the parts. (Probably from NewEgg.) I've settled on the Athlon XP 2500+ because it's the least-expensive 333MHz FSB chip, and am leaning towards Shuttle's AN35N-Ultra nForce2 Ultra 400 motherboard. Any reason I should consider another board in that price range instead? The Shuttle seemed to have good things said about it.
Also, I have a few questions on the memory: I've always used Kingston and have had no problems, so I'm leaning towards that as well. I want to buy a single 512MB PC3200 chip for now, and then add a 2nd later on when I can afford to spend a little more. Kingston's site recommends the KVR400X64C25/512 for use with the Shuttle motherboard, but I wasn't sure of the difference between that and their KVR400X64C3A/512, which is about $30 cheaper. The difference seems to be the latency (2.5 vs. 3-3-3), but I'm unsure if that will make a big difference or not. (Would it make a difference if I were to use this memory later on in a Socket 739 motherboard?) I'm also assuming that I can in fact use a single chip for now, and add a 2nd later on.
Finally, I had found a few cheap cases at NewEgg from Powmax and Dynapower. Any preferences there? All of my choices have at least a 400W power supply which should be more than adequate.
Thanks in advance for any advice and/or answers you can provide!
Rob
Rob
