Actually here is what i've got on the dump file. I don't know if someone could interpret it but I greatly appreciate it if someone can. I am really frustrated right now on this error, I can't see the pattern anyway it just randomly appears. Sorry for the long post.
Opened log file 'c:\debuglog.txt'
Microsoft (R) Windows Debugger Version 6.6.0007.5
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINDOWS\MEMORY.DMP]
Kernel Complete Dump File: Full address space is available
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is: C:\WINDOWS;C:\WINDOWS\system32;C:\WINDOWS\system32\drivers
THIS DUMP FILE IS PARTIALLY CORRUPT.
KdDebuggerDataBlock is not present or unreadable.
Unable to read PsLoadedModuleList
KdDebuggerData.KernBase < SystemRangeStart
Windows XP Kernel Version 2600 MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0x00000000 PsLoadedModuleList = 0x8055c700
Debug session time: Sun Nov 5 15:04:12.625 2006 (GMT+8)
System Uptime: 0 days 1:46:21.339
Loading Kernel Symbols
GetContextState failed, 0x80004002
CS descriptor lookup failed
Unable to get program counterGetContextState failed, 0x80004002
Unable to get current machine context, HRESULT 0x80004002
ERROR: FindPlugIns 8007007b
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {54, 1c, 1, 804faac3}
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
Unable to read selector for PCR for processor 0
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
?: kd> !analyze -v;r;kv;lmtn;.logclose;q
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000054, memory referenced
Arg2: 0000001c, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: 804faac3, address which referenced memory
Debugging Details:
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get MmPageSize (0x0) - probably bad symbols
00000054
CURRENT_IRQL: 1c
FAULTING_IP:
+ffffffff804faac3
804faac3 ?? ???
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xA
STACK_TEXT:
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: CORRUPT_MODULELIST
^ Unable to get program counter '!analyze -v;r;kv;lmtn;.logclose;q'
