Which models of USB WiFi Adapters sold by Aliexpress are good, stable and give a strong signal at a low price, and what functions are necessary for good performance ?
My PC IS i5 3470, 16gb ram ddr3, asrock b75m-dgs r2.0, Radeon R7 360, Power supply Corsair cx500, Windows 10, HDD 2.5" and ssd, monitor led ips LG 23.5" i lived in Brazil state Ceara
My router IS TP-Link wifi6 AX3000
I not have many money in. Aliexpress low cost
What IS the budget for this?I not have many money in. Aliexpress low cost
Giving us an actual budget number might help us to give you better advice.Netgear very expensive converting to Brazilian currency
I didn't know I would need to invest a lot of money for a good product
1 antena IS good or bad compared 4 antenas?Maybe this one in Brazil?
https://www.mercadolivre.com.br/kep...r-wifi-usb-wifi-antena-wifi-802/p/MLB22599122
Have you looked at that Amazon search?Maximum 8,50 Dólar IS possibly good adapters?
They are trying to pretend that the device can run 4x4 mimo. I have not seen a usb device that can run 4x4 mimo and even PCIE cards are very rare.1 antena IS good or bad compared 4 antenas
You want it cheap and what speed you are looking for? 4K video only requires 30Mbps. If one antenna can achieve 433Mbps then it's great.1 antena IS good or bad compared 4 antenas?
The one listed in Post #13 is almost certainly no crappier than anything else at that pricepoint.I don't have the technical knowledge to choose a good model to use on my PC. There are models with 1 antenna, 2 antennas, and 4 antennas. Amazon has more expensive shipping and taxes to Brazil.
The reviews are right on the site. wifi is always trial and error, no one knows the result until tested in that particular environment. Wall can be concrete, bricks, woods, drywall, etc. You will always get different result,I liked the price of the model in post 13, do you have any reviews of it? Is it stable and has a strong signal even with obstacles like walls and a distance of 10 meters from the tplink wifi6 AX3000 router?
I doubt you'd find any specific independant reviews of it.I liked the price of the model in post 13, do you have any reviews of it? Is it stable and has a strong signal even with obstacles like walls and a distance of 10 meters from the tplink wifi6 AX3000 router?
