Which models of USB WiFi Adapters sold by Aliexpress are good, stable and give a strong signal at a low price, and what functions are necessary for good performance ?
USB 1. , or 2.0 or USB 9.3.....it is unlikely you'll see "600mbps" via WiFi.
This adapter is USB 2.0 and my internet plan from the provider is 600mbps, will 2.0 be a limitation on downloads?
That "1300mbps" is a very deceiving not-quite lie.
https://www.mercadolivre.com.br/ada...00-5ghz-1300mbps-antena-wireles/p/MLB22541162Of the models mentioned here, which one do you recommend? Or any other in the price range that is not on the list?
https://www.currys.co.uk/computing/networking/wireless-adaptersMy PC IS i5 3470, 16gb ram ddr3, asrock b75m-dgs r2.0, Radeon R7 360, Power supply Corsair cx500, Windows 10, HDD 2.5" and ssd, monitor led ips LG 23.5" i lived in Brazil state Ceara
My router IS TP-Link wifi6 AX3000
I not have many money in. Aliexpress low cost
Those nano adapters are JUNK. To get good WIFI you need large antennas. The nano adapters have tiny antennas.https://www.currys.co.uk/computing/networking/wireless-adapters
The link is for a general electronics shop in the UK, think washing machines to televisions.
They have cheap USB WiFi adapters for as little as £9 to more expensive internal parts. If you are happy with TP Link the tiny USB part works well.
No need to go to Ali Express, see what local computer stores have close to you.
Not saying they are good but they work at a pinch. There are more options on the page at different prices. The point of the page was to show that even in a retail chain they aren’t that expensive, there is little reason to go to Ali express.Those nano adapters are JUNK. To get good WIFI you need large antennas. The nano adapters have tiny antennas.
At a minimum you want this -- https://www.amazon.com/wireless-USB-WiFi-Adapter-PC/dp/B07P5PRK7J?th=1
And this is better, because it has two antennas and is designed to work on a USB cable so it can be placed at the best location for signal -- https://www.amazon.com/USB-WiFi-6-Adapter-for-desktop-PC/dp/B0B5YPK9L1/?th=1
Yet you said "works well". IMO, that is not true.Not saying they are good but they work at a pinch. There are more options on the page at different prices. The point of the page was to show that even in a retail chain they aren’t that expensive, there is little reason to go to Ali express.
I would have to see the adapter with the "small" antennas ...For a strong signal 10 meters away from the router and with obstacles like walls, is it more important to have a large antenna or 4 small antennas?
https://produto.mercadolivre.com.br...a58-85c91e39c1ba&wid=MLB4118207075&sid=searchI would have to see the adapter with the "small" antennas ...
Post a link to that ...
My purpose is getting around a problem caused by a customer. They got bought out and blocked internet access for the kit I service.Yet you said "works well". IMO, that is not true.
So here a example of the massive issue with the "nano" style USB devices.My purpose is getting around a problem caused by a customer. They got bought out and blocked internet access for the kit I service.
Those little usb dongles work well for the required downloads and updates. For the purpose I use them they are excellent, cheap, cheerful and quick enough.
For gaming they are wholly unsuitable, granted.
The connection is immediate, data rate for my purpose is good enough, works well.
Doesn’t mean they are good. A SKMEI? Digital watch costs pennies too, it tells the time and is good enough at telling the time. Doesn’t mean it will last. Again, works well but is junk compared to a GShock.
Look beyond the first part, the page was posted to show that the devices are on the whole relatively inexpensive. That you can buy from a reputable source, not just Ali Express.So here a example of the massive issue with the "nano" style USB devices.
When I looked at the very first unit in the link you provided you can actually see the FCCid. They must file test documents with the FCC. Now very technically they might sell different units in the EU and the USA since the allowed transmit powers are different, it is 1000mw in the USA and 100mw in EU.
https://fccid.io/2AXJ4UB500
Problem is this device only puts out 9.4mw. That is only 1/10 the power allowed in the UK and 1/100 the allowed power in the USA. Most of brazil also allows 1000miliwatts on the 2.4g band.
This is very common for these extremely small units. They do this to save battery power which only matters on a laptop or tablet.
If you could actually get the FCCid on the units from aliexpress you could look things up. It is hard to get the FCCid numbers even on stuff sold on major sites like amazon. Most times you have to do lots of digging to get it but it is really the only way to be 100% sure of what the technical specs are. The methods for testing and measurement are very clearly defined unlike almost any other source of data including the manufactures own marketing data.
That is much less important than the size of the antennas. It looks like this is an "AC" standard chipset. It is an older standard.Chipset RTL8811 IS good or bad?
