I just have a few questions and I would greatly appreciate it if anyone answers!
1. Is everything compatable? if I put it together would it work?
2. Is it reasonable? my price range is around 600-700 dollars willing to go maybe a little over(which I did) Should I have a less expensive graphics card with that processor ? or anything
3. I've been doing a lot of reasearch on graphics cards and the Radeon HD 7850 seems to be pretty good for a reasonable price. What brand of it should I get? is the HIS an okay brand? does brand even matter when its the same card?
4. I think I may be using my 30 inch TV as my monitor. If I do get the Radeon HD 7850 card; should I get the 1GB or 2Gb? there is around a 30 dollar difference and the reviews on the 2gb seem to be a little better.
5. any tips or feedback?
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156062
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128519
Mother Board
-Comes with this RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161406
Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Cooler
DVD Burner
Case
Hard Drive
Mother Board
Video Card
CPU
Cooler
