Questions for Crashman
Some of the older HP Pavilion ATX M/Bs have a P/S additional 3 wire connector that hooks into a terminal at the upper corner of the M/B, close to this terminal is the CPU Fan header, what is that terminal for?
And can you use a regular ATX P/S to replace the P/S, or does it require a HP specific replacement P/S, because of that wire?
Thanks Ryan
<A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=2541&st=0#entry20385" target="_new">My Puter</A>
I've used standard power supplies in them, I think the extra wire is for fan monitoring...but why then it would have 3 wires rather than 1 wire on a 3-wire header, I know not. Still, I prevail at using standard power supplies in HP systems.
HP systems normally come with SFX or PS-III power supplies, which are both using ATX power standard.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Thanks I just didn't want to be responsible for blowing the thing up if that header turned out to be supplying power to the CPU fan header or something like that.
