So I purchased a super cheap old computer mostly because it was in this awesome customish case and it was the right price. But it has a pentium 4 plus all IDE stuff, the power supply is an alright one I believe it says Max 400 watts on it. But the question is how/what do I need to upgrade this? I am looking to go cheaper as all I want it for is to hook into the TV and be a media player/streaming server when I am not home.
the case is pretty tall and the current motherboard has 5 PCI slots I believe. What all do I need?! I am fine putting stuff in and configuring it all, but I am not the best at buying the parts. I suppose I should add that I want to install a blue ray drive as well.
So in short is this an adequate list of upgrades?
-Mobo (How are these measured? Do i need like inch measurements or will anything work in the case?)
-processor (what would you guys recommend? )
-Vid card with HDMI or equivalant out
-Multiple HD's (1 1tb to start with then the ability to add more because case is huge)
-Can I keep the power supply?
Thanks so much!
Thanks so much!
