Hello
currently I have an AMD XP 1700+ Palmino core cooled by Vulcan 6cu(4000rpm). The noice is horrible and I would like to ask you if a 2300 rpm cooler wont burn my CPU
I was wondering to get the Spire WhisperRock IV™, will it be ok for an AMD cpu? I even consider buying a cooler version of the CPU wich works on 13u.
The bottom line is : How can I cool my AMD cpu with a quiet solution, and not burn it ( I live @ a hot country )
(http://www.spire.nl/frames.html)
