Question Quiet fans
Jul 27, 2024
Thinking of buying one of the new Antec C8 cases. The question is what fans to put in it? I treasure quiet above all but fancy some ARGB as well. I currently use CM Silencios and love them because they're so quiet, but they don't make an ARGB version so far as I can tell. Are there any ARGB fans that are as quiet as Silencios?
Reactions: CountMike
Most fans can be made silent by adjusting their speed in the BIOS or in software that the manufacturer provides (or in 3rd party software). The only question is how much air they move whilst being silent.
I would say that the currently best performing fans with ARGB features are the Lian Li Uni Fan TL 120 / 140 fans. The RGB is really fancy, and they move as much air as the P28s. They're also 28mm thick, so be aware of that.
Depending on how much cooling performance you need for your system, you could get away with much cheaper fans...
Thermalright C12S are a good budget pick if they are available in your region.
Otherwise Arctic P12/P14 ARGB.
BEWARE the "trick" of setting fans to a slower speed than the default "fan curve" pre-set in your mobo BIOS. Of course, setting the fan slower makes less noise. BUT that also means you are NOT getting as much cooling as you need. Worst case scenario is using the "Quiet" or "Silent" option for a fan header. This means a FIXED slow speed that cannot ever increase when your CPU is working hard, so it WILL overheat any time you do a lot of work.
OP, you are on a better path by asking for recommendations of fans that normally run more quietly than most for all speeds.
