Quiet HS/Fan for 8RDA+
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
I have an 8RDA+ with an Athlon 3200+ XP CPU overclocked to 2.4 Ghz. I have
a 5500rpm fan on right now (sorry, don't know what it is) and I would like
some advice on the quietest fan/HS solution for this type CPU.
Thank you!
Michael Sovitzky
MCSE: W2K
Andy
1,239
Aero 7 Lite CPU Fan for AMD XP 3200+ and Higher Processors
Manufacturer: Cooler Master
<http://www.compusa.com/products/product_info.asp?product_code=316278&pfp=srch1>
On Sun, 06 Mar 2005 23:30:11 GMT, "Michael Sovitzky"
>Thank you!
G
Guest
Guest
>Thank you!
I've found that the really expensive ball bearing fans are very quiet
per cfm while the really cheap fans are very noisy.
My Peeze fans are in the middle.
PJ
G
Guest
Guest
thermalright si-97 with papst 8412 n2gl is the best combination you get
get on the planet.
> Thank you!
G
Guest
Guest
http://www.coolermaster.com/index.php?LT=english&Language_s=2&url_place=product&p_serial=ACC-L81&other_title=+ACC-L81+XDream%20III
Robert J. Salvi, Ambiance Acoustics
http://www.ambianceacoustics.com
San Diego, CA USA
(858) 485-7514
"Michael Sovitzky" <msovitzky@c-gconsulting.com> wrote in message
news:7oMWd.18960$3V3.1188@twister.rdc-kc.rr.com...
> Thank you!
> Michael Sovitzky
> MCSE: W2K
