Question R7 360 Graphics Card Not Working Please Help
Jan 17, 2020
Hi my gigabyte r7 360 oc is facing issues. It worked well for 3 years.
  1. No display output. Hdmi or DVI doesnt give signal.
  2. When I boot up using motherboard hdmi windows lags a lot and after about 3-5 minutes it freezes and i have to cut off power.
I am using latest drivers. My power supply and pcie slot is ok.
Shows up in the task manager before it freezes.
image 1
Gpu-z shows this
image 2
Please somebody recommend me a fix. I cant afford a gpu now not even 2nd hand.
full system spec? include make and model of the psu
what the cpu/gpu temp?
malware scan your system?
Gigabyte b150m ddr3 mobo
16gb ddr3 ram
Intel Pentium G4560
Corsair VS450 450W power supply
Scanned for malware after disconnecting gpu with kaspersky. nothing found.
Cpu temp is normal 35 idle 63 full load.
Gpu temp is hard to get cause windows lags so much after booting. I touched the gpu heatsink and it felt ok nothing too hot.
