Hi i want to play my games normal i hope someone can help me!
i got a new game pc 3 weeks ago, but the problem is since the beginning i got problems with my fps drops, on all resolutions! example : if i play high on bf4 i get 60 - 80 fps but sometimes once in the 10 min, i get a drop to 20/30 fps, even on small streets with almost no textures.
and it happens also on low, on low i get 125-140 fps. but then randomly the same thing happens it drops to 20 - 30 fps,
very annoying in a fight,
MOTION blur and Vsync = off.
it happens on all games,
MY SYSTEM
8GB RAM
r9 270X
FX 8320
Corsair VS Series VS650 W
MSI AFTERBURNER TEST RESULTS AFTER 20 MIN PLAY ON MED / HIGH.
GPU heat : 61 C
GPU USAGE : max 99
fan speed : 46
fan : speed meter RPM : max 1901
Core MHZ : 1070
memory clock : max 1400
memory usage : max 1491
CPU 1 : 92
CPU 2 :92
CPU 3 : 93
CPU 4 : 98
CPU 5 : 100
CPU 6 : 94
CPU 7 : 100
CPU 8 : 84
RAM USAGE : max 4939
pagefile usage MB : max 6675
and BF4 testscreen results
it uses 1556/2048 RAM
8 cores
4 job threads
fps was a steady 100 / 125 on water and on land mostly 100 - 80 , and then the drops once in the 10 minutes, to 20 10 and sometimes there were drops to 60
I hope someone can help me with the problem
Melvin!
MY SYSTEM
8GB RAM
r9 270X
FX 8320
GPU heat : 61 C
GPU USAGE : max 99
fan speed : 46
Core MHZ : 1070
CPU 1 : 92
CPU 2 :92
CPU 3 : 93
CPU 4 : 98
CPU 5 : 100
CPU 6 : 94
CPU 7 : 100
CPU 8 : 84
8 cores
4 job threads
Melvin!
