R9 390 Sapphire TRI-X temperature
redzinter
21
Is it normal for R9 390 Sapphire TRI-X to run on witcher 3 ultra setting on 60-70 C ? whats max temp that would be ok?
Doesn't mean it should be considered normal IF the graphics cards reaches temps like that. You want to keep it below 75 degrees. 60-70 is very normal like said.
Well it is totally normal for the reference blower cooler versions to hit 95'c, so AMD consider that safe. Where have you pulled 75'c from?
It was just a reminder for any reader that open this thread and reads your post with ''95 degrees and under is totally safe'' that he doesn't start thinking that an R9 390X Tri-X or whatever non-reference card running above 85+ degrees is normal. That's all it was. Basically, it wasn't intended as a personal reply at all it was just a reminder that such a card shouldn't run above 75 degrees even if up to 95 is safe.
