Question Radeon installer will not work
26
After upgrading my build and getting help with clean install I now have another problem my radeon rx 6600 xt is installed correctly the lights and fans work and was used in previous build but does not show under anything. I have tried to download the drivers from amd website but get error 173. The card is used and came with no disc. I have updated the motherboard and using the cpu integrated graphics. There are no drivers on C just the fresh win10 install, what can I do?
Intel core i7 6700 (intel hd graphics 530)
Asus prime b250m-c
Corsair vengeance 16gb ddr4
radeon rx 6600 xt 8gb
Update
I found my old GeForce 750ti and it's letting me install the drivers I have HDMI cable from card to tv. I just don't understand though why the other wouldn't work.
View: https://imgur.com/a/14q6p78
When you reinstall a video card into a system, please take care at the PCIe slot.
Reinsertion should be done at the right angle.
Please check if the card is correctly inserted in the slot.
The second thing you should check after that is the PCIe power cable.
You need to insert that 8 pins cable in your card until you heard that click or you see it is well inserted and in place.
When you made a new build, what PSU you used for the new build?
Cause if the card was functioning properly before, there is a question mark over the PSU itself.
AMD Radeon RX 6600 XT draws power from 1x 8-pin power connector, with power draw rated at 160 W maximum
psu is segotep gn650w 80 plus gold.
Well, i am not here to discuss the quality of your PSU.
But i have some doubts regarding the quality of that PSU.
So, in order to eliminate the card from the list, take your card to some friend and test it in another system.
That will eliminate it from the list.
After that we will go further with testing
Hey there,
Whilst it may not be the cause of your issue, I would remove that PSU from the system. It is not a reliable PSU. Even though it's gold rated, there's no doubt the components themselves aren't quality. The fact that it's cheap and has practically no reviews are red flags!
Regarding the GPU, I'd agree with @Imperat0r . Test in another system. Otherwise, it's most likely dead.
Are there any noticeable marks, or anything around the PCB?
Reactions: Imperat0r
you are getting video output from the card but it is not formally detected by the system?
the best Segotep i've seen is mid-range quality, the worst potentially dangerous.
i would definitely try this card with a known higher quality model, if you have someone with a better setup available to test in.
you definitely want motherboard drivers and the latest BIOS installed so you know the PCIe and other devices are properly controlled.
couldn't get anything from HDMI off of card was using HDMI on mb.
I don't have any friends that have PC. I was using GPU and PSU in ASRock h610m-hdv
Hey there,
I'll try to get a better one later
have you installed all motherboard drivers from the manufacturer's product support downloads page(s) and updated to the latest BIOS?
Yes and the AMD driver was there but it would give me error 173
i get that you are receiving a "hardware not detected" error about the card.
just making sure you have latest chipset and all available ASUS motherboard drivers installed along with the latest BIOS version that would include any available fixes.
I updated the BIOS to version 2001 I think. The AMD drivers they list on the mb website is the installer from amd's website so I assumed that it didn't go on the flash drive with the BIOS update and tried the AMD install after BIOS update. I don't know about the other things I looked some of the other things up but didn't understand what they were for. Was I supposed to put the stuff on the drive with the BIOS update and flash?
Don't know if that is stupid question but I don't know a lot about this stuff.
Hey there,
No the mb came very clean information said pulled from another PC. I don't understand how it worked in the previous with the one right before I started this one
Can you post a picture of your device manager. It will give us a quick reading where you are with drivers installed or not.
Even if your still having issues with the GPU driver installing seeing what is installed or not will fast forward where we are helping you.
you can post picture to imgur.com than link that page here.
I will do that tomorrow, I installed the GeForce 750 ti so it will probably show that.
