Question Radeon installer will not work
26
After upgrading my build and getting help with clean install I now have another problem my radeon rx 6600 xt is installed correctly the lights and fans work and was used in previous build but does not show under anything. I have tried to download the drivers from amd website but get error 173. The card is used and came with no disc. I have updated the motherboard and using the cpu integrated graphics. There are no drivers on C just the fresh win10 install, what can I do?
Intel core i7 6700 (intel hd graphics 530)
Asus prime b250m-c
Corsair vengeance 16gb ddr4
radeon rx 6600 xt 8gb
Update
I found my old GeForce 750ti and it's letting me install the drivers I have HDMI cable from card to tv. I just don't understand though why the other wouldn't work.
View: https://imgur.com/a/14q6p78
I got everything downloaded unpacked and tried to install, failed on eveyone said nothing to install or not found.
On a whim what setting are BIOS set to Legacy or UEFI. The GTX 750 can work in one or the other but the AMD Radeon RX 6600 XT is UEFI only
It's UEFI I thinkO
There are 8
1-4 is uefi hdd,CD-ROM,USB,lan
5-8 is legacy I tried to change legacy but it switches uefi ones to legacy.
It's UEFI I thinkO
There are 8
Those have nothing to do with your problem and disks can't be UEFI or Legacy, Bootable disks can be formatted with MBR table that usually goes with Legacy/CSM BIOS or GPT with UEFI form of BIOS.
Your BIOS can be set to CSM=Legacy mode and when you disable CSM it will switch to UEFI mode.
Drivers are always installed on the disk you boot windows from on C:\ partition and it really doesn't matter from where they are installed, HDD,SSD,USB dongle...
For AMD GPUs, when you run driver.exe file it unpacks it to folder C:\AMD and installs from there.
Latest driver is Adrenalin 24.7.1 available from AMD site. Driver name is
whql-amd-software-adrenalin-edition-24.7.1-win10-win11-july19-rdna.exe
If driver fails to install something must be wrong with your Windows or not up to date. Adrenalin and drivers run on .NET environment so up to date .NET runtime library has to be up to date too.
First check for Windows updates and run SFC /SCANNOW from Command prompt (As administrator) which should show any widows corruption and fix it.
I checked and eveything is up to date but still cant install the amd software. I am truthfully about to give up on the rx 6600 xt and just look for another geforce and psu like Imper0r suggested.
I got everything downloaded unpacked and tried to install, failed on everyone said nothing to install or not found.
the mb came very clean information said pulled from another PC
are you sure you're looking at the correct product support page(s)?
you have the box and documentation for this board to verify you are looking for the right model and iteration of this model?
if you have no box or documentation that came with the board;
you will need to verify which exact model either by nomenclature on the front of the board or a serial sticker on the rear of it.
it's possible that this is even a damaged or malfunctioned product since you have received it in the manner that it seems to have arrived.
This is the board I ordered. I go to the Asus support for the board and make sure that win 10 is what is picked
https://www.ebay.com/itm/2049133032...A4zof8FQj-&var=&widget_ver=artemis&media=COPY
it doesn't matter what the ad says.
it matters what actual board you have in your possession.
many times with used hardware people will lie about what it is, or even just be mistaken altogether.
the fact that installing the drivers leads to a "not found" error means that you need to verify for sure what board it actually is.
Okay I will check the back of the board.
It's and Asus prime B250M-C, find manual and latest BIOS file here
I had updated the BIOS from 1205 2018/06/01 to the 2001 2021/08/10, along with all windows updates and .net and the gpu still would not work. My gpu is good cause I took the prime mb out and put my asrock h610m-hdv back together in case out of frustration from the other not working with gpu. I'll just have to recearch my parts a lot more and longer than a few days. thank you for trying to help me though.
