G
Guest
Guest
I bought a system to make a video editing system consisting of:
Asus a7n 266e MB Rev 1.3
512mb x 2 kingmax DDR RAM
AMD 1800+ XP
3 Maxtor 40 Gig hard Drives D740X 6L040J2
ThermalTake Volcano 7 cpu fan
case w/4 case fans 350W amd ps
HP dvd 100i
sony cdrom
3.5 floppy
Iwill Side Raid 100
Pinnacle DV500+ video editing card
Windows XP PRO
I assembled all the MB in the case, with 1 maxtor connected to the MB secondary master, and the hp dvd 100i on Primary master and sony cdrom on Primary slave. I booted up, and installed XP without a single hang or error. I then installed a 56k modem and updated and activated windows.
I downloaded the latest revisions of bios for the MB (1001.b) and found new drivers for all the hardware. Meanwhile, I set the video to 1024.x768 16 bit 85hz and changed the windows theme to performance and turned of some unnecessary services. Used tips and tweaks from video guys http://www.videoguys.com/WinXP.html
I installed the rest of the hardware Iwill Raid slot4 pci, Pinnacle dv500 slot 3 pci and rebooted windows. Still no hangs or problems. And the system seemed blazing fast. Got premiere 6.01 installed and the dv500 plus software. I Configured the Raid to Raid 0 with 64k stripe and formatted the 2 drives (each on master of each raid channel) with ntfs 64k block size.
Now the problems started.
I could not capture video to the raid system without dropping 1/3 of the frames. I used the Dvexpert utility that came with DV500+ to test the raid system. I was getting 2.84 MB/s write speed average for a 100MB test file. The read speed was about 80 mB/s . I tested the c: drive connected to the onboard controller, and got about 20 mB/s write speed and 35mb/s read speed.
Consequently, I updated the Iwill controller drivers and software from the Highpoint website to ver. 2.31 and still no difference. I tweaked the memory timing to 2.0 turbo and back to default. I disabled the onboard LAN, Sound, and USB hub also moved the cards to different slots with still no difference. In all of this I had to call and reactivate windows. I downloaded Powermax from the maxtor website and checked all the drives. Powermax gave a good report on the drives, and I checked to make sure write verify was off. I moved the DDR ram to different Banks to no avail
At this point, I just tried to capture a video to the C:drive... 740 x 480 ntsc 29.97 fps and 30 minutes later I had not dropped a single frame. I stopped the capture, and tried to play back to the DV500+, guess what: 1/3 of the frames dropped when trying to play back to the dv500.
Sensing some type of conflict, I removed the DV500 and retested the Raid. Still 2.84 mb/s. I went into bios and started tweaking the frequencies down from 133/266 but the write speed stayed around 2.84mb/s however the onboard ide and Raid read speed would slow down. The onboard IDE functioned just fine.
At this point, I ripped out the modem and still about 2.84 mb/s.
Ok, I get on the phone with Asus tech support and the technician tells me I should not be trying to edit with a AMD based system. He says they only meant for it to be a gaming system and that 2.84mb/s doesn't seem to be out of line for the PCI bus. He tells me to check for windows drivers and that as far as he is concerned it can't be a MB problem.
I call Mwave where I ordered the MB and they asked me to reinstall windows, and gave some more suggestions such as checking cables, voltages etc. I Reinstalled windows (with yet again sitting on the phone with MS waiting for a 46 digit activation code) and checked everything. Still all I had was approx 2.84 mb/s write speed to the Raid 0 array of 2 40 gig D740X drives.
Mwave gave me an RMA for the Asus and shipped me a K7N 420 Pro MSI.
I installed the msi with the hp dvd 100i to the onboard IDE primary master and sony cdrom to onboard primary slave. A maxtor D740X was installed on the Secondary master with no secondary slave. I installed the Iwill Raid in pci slot 4 with each D740X on its own channel master.
When I booted from the WIN XP cd and hit F6 to install raid drivers, I installed the updated v2.31 and got a crash for invalid scsi drivers. I merely rebooted and let the install run with the win XP drivers. WinXP installed and came up. I configured the display to 1024x768 16bit and 85hz and installed the updated Iwill Raid drivers. Shut down and Windows hangs on restart at the starting windows screen. Reset and boot to last known good configuration. Try to install the raid configuration software, and it goes fine but when I try to configure I get Configuration failed message. Shutdown restart and hit (control H) and there is the configuration just fine. Try to continue booting, but hangs on starting windows screen. Reset, do (control H) delete the raid, start windows to last known good. Enter disk management initialize the raid drives individually with ntfs quick format 64k block. Shut down restart (control h) add raid 64 k stripe and it boots up.
I shut down and install modem. Fired up and changed the bios to 133/266/66 timing and it boots. I downloaded the latest bios for msi (6.00 pg) and got the latest drivers from nvidia site. I installed the drivers and shutdown and loaded the new bios. The Beast booted. I install the 2.31 driver for the raid card and shutdown restart. It hangs on starting windows. Shutdown restart last known good. It boots. I put in cd with Dvexpert on it and test raid – about 3 mb/s write speed and 30 mb/s read... I test the onboard IDE c: drive and get about 20 mb/s write and 35mb/s read.
I decide to play with the MB frequency and with 100/200/66 CPU/MEM/AGP timing I get about 15 mb/s write speed to the raid with a 35 mb/s read speed. I decide to go get another raid card and try that.
I get a 1200A adaptec from CompUSA and install it.... exactly the same results.
Both the Iwill and 1200A adaptec have Highpoint 370A chips. Both motherboards that I have tried have Nvidia chipsets. I have not been able to install another OS yet, to try that, but I am going to buy another motherboard today with probably a via chipset and try that. I thought maybe the Dvexpert test software was the problem, so I did a drag and drop test from the C: drive to the Raid and it took roughly 30 seconds to transfer an 85mb folder.
It seems to me that there is a major problem with either WIN XP pro/ Highpoint raid drivers/ Nvidia chipset drivers/ Nvidia chipset design/ or bios. I don't think 99.99% of the people using these systems will ever notice because you have to need to send over about 2.5 mb/s out over the pci bus to your peripherals to ever notice. Performance from the peripherals into the system over the PCI bus is blazing especially with the ASUS. But I never edited the registry and tuned the system for performance with the MSI. I never had the 1st hang or error with the asus board, I am just frustrated with the Raid Write Issue.
Any Help is appreciated.
Win XP activation is HELL to go through with a system problem.
Termination for XP Activation
AMD 1800+ XP
HP dvd 100i
sony cdrom
3.5 floppy
Iwill Side Raid 100
Windows XP PRO
