Question RAM debug led stuck on solid white ?
Oct 8, 2022
So this is my situation, I’ve had my pc for about 4 years and decided to get a new case, once installed into the new case it turned on for a few seconds then automatically turned off, I did some minor troubleshooting and got it to turn on again to find the ram debug led solid white, what do I do now? I’ve tried a single stick of ram and both sticks in all possible configurations and nothing is working
Motherboard- z270-a pro
Ram- vengeance lpx ddr4
Update your post to include full system hardware specs and OS information.
PSU: make, model, wattage, age, condition (original to build, new, refurbished, used)?
Disk drives(s): make, model, capacity, how full?
"I did some minor troubleshooting and got it to turn on again "
What did you find and what did you do to get it to turn again?
What was the reason for getting new case? Cosmetics or some problem(s)?
Do you hear any beep codes (some pattern of long and short beeps) when system fails to start up?
Will the system boot into Safe Mode? Are you able to get into BIOS?
That all said, I recommend a bright flashlight look at the case, motherboard, I/O panel installations, and case panel connections.
Maybe a short around the I/O Panel.
Verify that all connections are correct plus fully and firmly in place.
Hopefully just some error of omission or commission.
Reactions: Dark Lord of Tech
