Question ram speed capped at 2133mhz
Dec 27, 2019
Gigabyte Technology Co. Ltd. Z390 AORUS ELITE-CF (U3E1)
my ram is stuck at 2133mhz and when i enable xmp it fails to boot
i have https://www.overclockers.co.uk/patr...dual-channel-kit-pvs416g440c9k-my-103-pa.html
i am aiming to achieve higher boots clocks for my ram to round about 4400mhz if possible
i have searched on the web and i havent found anythink that will help me out
i have also asked friends about the issue however they do not own the motherboard so they cant help
your board doesnt officially support 4400mhz looking at the spec sheet, and i didnt see any additions in the bios update descriptions, according to Aorus website, max supported speed is 4266 (OC), maybe you should try to manually set the speed at 4266 and C19
