Hello
It is time that I create my own thread after reading through many threads that are similar to my problem but not quite the same.
I have been experiencing random audio stutters and fps lag spikes every now and then in almost all of my games, it wasn't a big deal since it didn't occur as often, until I started playing The division, even on the lowest settings.
I've been monitoring everything via Task manager, and everything seemed fine other than the Memory reaching 80-90% usage, so I used Resource monitor for more details...
Memory usage while idle:
http://prntscr.com/jy1lkb
Memory usage while playing:
http://prntscr.com/jy1nf9
I'm not familiar with how RAM works, but I have a theory which might be wrong
Since the game's minimum memory requirement is 6GB and I have 8GB of memory,
2GB is used by the system + 4GB while playing which means the game is only using 4GB while the minimum is 6GB, so that got me wondering if my RAM isn't enough, unless it is something else thats causing this issue.
Help and suggestions would be much appreciated.
My build:
Cpu: Intel core i7-3770
Gpu : Geforce GTX 960 4GB
RAM : 8GB
Mobo: msi ms 7788
SSD: playing on a SATA 3 SSD which is connected to SATA 2 port
My build:
RAM : 8GB
Mobo: msi ms 7788
