Hello friends.
I recently built a new PC with the following components:
Intel Core i7-9700K CPU
ASRock B365 Phantom Gaming 4 Motherboard
Corsair Vengeance LPX 16GB (2x8B) (CMK16GX4M2B3000C15) RAM
EVGA GeForce RTX 2070 Super GPU
The PSU I am using with these new parts is from my previous build: Corsair HX750W Silver
I should note that the PSU was purchased used from a friend and might be 5+ years old by this point.
The PSU seemingly worked fine with my old build until I built my new PC on 12/05, but I am now suspecting that it might be the culprit, though I'm not really sure. As far as I could tell, there were no random restarts for the first few days, though they may have occurred without my noticing while I was away from the desktop. From what I can tell, it appears to happen maybe 1-3 times a day, in and out of games. There is no BSOD and I also couldn't find any dump files when using the Windows Debug. Windows simply says "Restarting".
I tried the following to diagnose/resolve the issue:
I monitored my CPU and GPU temps under load (while playing a demanding game). The CPU cores never exceeded 57 °C and my GPU hovered around 80-90°C. This leads me to believe that overheating isn't the issue, especially because the restarts happen even when the system is idle.
I turned off automatic update restarts, as well as automatic restarts in the system recovery tab. I even created a registry key to prevent automatic restarts.
I ran the Windows memory test (though perhaps I should use Memtest86 instead?) and it found no issues.
I reverted to an older Nvidia driver.
I updated my BIOS to the latest version.
I changed minimum process state to 0% and changed power plan to high performance.
The next steps I plan on taking are:
Purchasing a PSU tester to try and diagnose the PSU.
Removing my GPU and using onboard graphics for a while to see if the GPU might be faulty.
Doing a clean install of Windows or using a restore point.
Do you have any advice as to how I should proceed troubleshooting? I'm sure there are plenty of other steps I haven't yet taken or thought of. For example, diagnosing the CPU or Motherboard would be helpful, but I'm not sure what the best way to go about it is. For what it's worth, my PC performs very well in demanding games and appears to function perfectly fine, until the spontaneous reboots rear their ugly heads. I also have multiple hard drives connected to my PC. What would be a good way to test my drives?
Thank you in advance and please let me know if further information would be helpful.
