Hello People,
Name is Neph. I have very recently added a Corsair H100i Elite Capellix to my build. Performance-wise, there are no issues at all. It purrs like a kitten, cools like the north wind. However, ever since I installed it on the 1st of February, the pump flashes white at random intervals (sometimes twice in 1 minute, sometimes once in 10 minutes, etc.). I have mild sensitivity toward sudden flashes, so it bugs me a lot. Here is the checklist I have gone through so far to identify the problem:
- I have double-checked iCUE lighting settings to confirm that it is not caused by a lighting pattern problem.
- I have verified that there is no conflict between my RGB management apps.
- I have tried different cooling presets to confirm that it is not some sort of cooling error response.
- I have checked and confirmed the pump tach wire's integrity and its connection to the CPU_FAN header.
- I have checked and confirmed that the RGB cables are properly plugged into the Command Core.
- Case: Phanteks Eclipse P360-A D-RGB ATX Mid-Tower (+ 1 extra Phanteks SK120 D-RGB PWM exhaust fan)
- Motherboard: Gigabyte B550 Aorus Elite Ax V2
- CPU: AMD Ryzen 5 5600x
- CPU Cooler: Corsair H100i Elite Capellix 240mm AIO
- RAM: Corsair Vengeance Pro RGB 2 x 16 GB DDR4 3200 MHz CL16
- GPU: Asrock 6800XT Taichi X
- SSD: Kioxia Exceria Plus G2 1 TB
- PSU: Corsair RM850 Full Modular 80+ Gold
