I have an interesting situation that i just can't get figured out on my own. In summary i am building a new PC for the first time. Parts are high end (gigabyte ga-k8nxp-sli, amd 4000, corsair, a 200 gig storage drive and a 74 g raptor for OS and applications). For installation, i only have the Raptor with jumpers set at cable select and into S ATA on the motherboard (i dont think it matters which port, but it is 0). When installing windows xp pro, i get through inital phase of finding the drive, copying the files and when its done, the list tells you to remove the disk from a and then it restarts). At this point the machine hangs up on a black screen with a prompt (effectively a dead prompt). this hangs up the installation procedure. Of course, if i leave the install disc in, it just starts all over again.
I have done many clean installs using an ide drive and never had this sort of issue. Since windows wants to put files up onto the raptor, there would be no sense in needing additional driver install.
Well, i am just stuck on this one. Any help, or even just a different was to look at the problem would be greatly appreciated.
-cory
-cory
