This Raspberry Pi project was developed to help improve sanitary conditions by utilizing UV LEDs.
Raspberry Pi Project Sanitizes Masks with UV Light : Read more
UV-C light definitely has proven sanitation properties, it is also quite dangerous and totally invisible. You can get a radiation burn (sunburn) off of a UV-C lamp in a couple minutes, but thankfully it doesn't penetrate most glass or transparent plastic. UV-C lamps need to be made out of a special quartz glass that the light can pass though.
The near-UV purple light put out by common "UV" leds might make florescent paint shine with that blacklight glow, but it's not so effective at toasting germ DNA.
UV-C leds are rare, exotic, expensive, and emit no visible light. They also are not really more efficient or cost effective than using an older florescent tube lamp. Those gas-filled UV-C lamps will emit a blue glow as a byproduct of producing UV-C, but LEDs do not have this byproduct. If a "sanitizing UV" LED is producing a blue or purple light, then it is fake and ineffective at sanitation (even if it makes blacklight sensitive colors glow).
Now the Box of hope webpage is a bad mobile site with no technical information, so I have absolutely no idea what kind of kind of LED hardware they sourced for this student project. Just be aware of the limitations of UV-C before buying/building a fake germicidal product. There is a huge amount of scammy snakeoil and fake garbage on the market, especially since the pandemic. It's best to just steer clear of the led products entirely right now, and stick with the florescent tubes.
So most of the "UV Lamps" you can find on sites like ebay or amazon are just fake regular blue/violet lamps? for example there's a "Philips UV-C Disinfection Desk Lamp [Energy Class A+]" lamp listed at about $130 on amazon but the only picture is just a stock photo with the lamp emitting a dim blue-ish light and looks made out of cheap plastic not quartz.
