Rate/Critique my first build
Flabbies
Hey guys. So I've spent quite awhile researching and comparing parts and have finally came up with something that is in my budget and I am pretty happy with.
I want this computer for gaming and personal use, life surfing the web or doing things for school. I'm pretty sure this build will meet what I want, but since it is my first build I just want to make sure all these parts are compatible and if this is an OK build. I'm especially unsure of the power supply and optical drive. I tried to calculate the wattage and I think the one I chose should be enough and the optical drive, even though I'm sure I'm way over thinking it, is just confusing to me for whatever reason. :??:
tl;dr
Will these parts work together and will it be a decent gaming computer?
If I could just get some feedback, recommendations, or any advice really, that would be fantastic. Thanks!
Parts:
Mobo - Intel BOXDQ77MK LGA 1155 Intel Q77 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121623]
CPU - Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504]
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314]
GPU - ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446]
HDD - Seagate Barracuda ST500DM002 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767]
PSU - Thermaltake TR2 W0070RUC 430W ATX12V V2.2 Intel Core i7 Compliant Dual 80mm Fans Full Cable Sleevings Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023]
Optical Drive - ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204]
Case - Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case, comes with Three Fans-1x Front Blue LED 120mm Fan, 1x Top 140mm Fan, 1x Rear 120mm Fan, option Fans-2x Side 120mm Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153]
My budget is about $750 but I could probably push $800-$820. I would probably overclock but it isn't guaranteed. I also wasn't planning on doing SLI or crossfire, at least not in the near future.
That looks great, and is definitely cheaper than what I had. One question though, why the step down from the 3570K to the 3470?
