I was gifted a 4070s this Christmas and had to get a new PSU with a 12vhpwr cable to power it. I've done some reading that if the 12vhpwr cable has any gaps in the connection it can melt, so I'm paranoid mine is going to.
It is clicked in to the socket, the only issue is that my case is a bit small and the side panel presses up against the cable. I would really like to avoid buying a new case if I can. I've tried pressing it in even more without the side panel on and the cable usually just drops back down a bit because it's so bulky...
What do you think? Does this connection look safe to use?
View: https://imgur.com/a/rate-12vhpwr-connection-0EeCnkc
