Razer blackwidow x chroma LED
andromedaftw
108
Hi guys, i dont know if this is the right category. I just got razer blackwidow x chroma, I just want to ask if using the bright (max) brightness in LED light can shorter its lifespan and it'll make it dimmer after its long use? Thanks in advance.
After some quick research i have found the answer. Yes, this applies to pretty much any light source. Running lights at a higher output will have an effect on lifespan over time.
