So recently I've had problems with my Razor laptop power throttling which makes my core speeds dip down from 4,1Ghz to 3,2Ghz when stress testing. I don't understand the issue. I recently cleaned and changed thermal paste and my temperatures are in the mid 60s when under heavy load. The power is maxing out but my cores are stuck. I have undervolted my cpu with throttlestop (see pictures) and even tried Intel XMU but nothing works. I always pull max speed on my fans so thermal throttling is definitely not the issue. I use high performance mode on windows, i've even turned power throttling off via regedit.
Issue 1:
My core speeds are low when they shouldn't be.
Issue 2:
My laptop should be able to pull 45-60W but it's stuck at 35W under load.
Check pictures for more info!
Anyone have a solution? Any help is useful
Issue 1:
Issue 2:
