Razer Copperhead Boot Problem!!!!!!!
mitchy
I purchased a copperhead and installed firmware with no problems. But then when i turn pc off and then back on the usp is not recognising the mouse.... I do not want comments such as you should of got another mouse, please simply a way to fix this probelm, if there is one.
It would be much appreciated
have you tried plugging a mouse into the ps/2 port and then re-attaching the copperhead after windows has booted? also, try a usb->ps2 adaptor.
hi,
i just found this site while looking for a solution to the same problem
if mitchy found a fix could he/she let us know please how to fix it
Is plugged into a USB 2.0, and have you updated the bios? and have you looked at your bios settings....just some things to look into before going ape :lol:
hi, you have to email here: betadrivers@razerzone.com
and ask for the beta 6.1.7i firmware drivers. i installed them and they seem ok at the moment.
if you have any more problems with the mouse let us know
does anyone else think this mouse is worth £50?
I have the problem of not being able to use the copperhead in any other usb port than the one in which I initially installed the mouse. Usually I can plug any usb device in any port and XP does the behind-the-scenes tasks to get it to work.
Did you switch ports and forget? I guess if you uninstall the drivers/software and reinstall to the port you want, that could work.
I hope I'm being helpful.
I had the same problem!
Wait till you've had it a few weeks, the lenses will start to get dirty, and skip, and stutter.
I took mine back and got me the Logitech G5! I am so happy I did too!
Good luck with that crap mouse.
I posted about this problem already, but put in wrong area, AMD!
Thanks all. I have found the solution, i got given the v6.17i firmware and it works fine. And the mouse is awesome not "crap" at all. Glad to have it 😀
