[SOLVED] Razer kraken te with usb audio controler mic way to quiet cant hear at all
HjalmarE
11
Mic is to quiet to hear, somehow it sounds perfectly normal in the synapse app before resetting my pc the 2nd time but now it only works with mic monitoring and not the mic preview, windows and discord detects the mic but the sound is barely audible with max input volume.
I have check mic privacy setting and all 3 of them are on, mic is not muted in sound settings, everything is turned to max volume. Things stopped working after I reset my pc and after resetting it again it still doesn't work. I Deleted drivers and it still doesn't work. I also tried a firmware update through synapse. Also did nothing. I'm kind of out of options, anything to try would be appreciated.
Windows 10 pro
32gb ram
64bit os
i7-7700k 4.2ghz
1070
Razer Kraken Tournament edition wierd gaming headset with usb audio controller (black) has thx spatial audio supported
I noticed under device manager I had some stuff connected to the razer controller under Sound, video and game controllers instead of Audio inputs and outputs or Audio Processing Objects (APOs).
