blazorthon :
bokeh :
blazorthon :
Wask :
oh, you keep going on about battery life, for one its a gaming laptop you are not going to get away from the fact you are going to have to take the power brick with you! The razer which actually can run games off the battery without throttling and 4hrs+ on normal settings isnt shabby considering virtually every other gaming laptop cannot run their gfx unit unthrottled without the power cord...
I never said that it was bad about battery life, only that some of my other suggestions had better battery life.
The article blatantly states that there is throttling from being off the battery. It's not very bad at all, probably not even noticeable, but it is throttling.
C
The GPU comes out of turbo mode on battery and runs at stock clocks. If the CPU or GPU operated below normal frequencies, I would call that throttling. The Blade does not throttle on battery, it just backs off on overclocking the GPU.
That is the wrong side of a semantics argument. The Blade has a higher stock frequency, so it is in fact throttling based on the Blade's specifications. What you call it doesn't change what the official meaning and definitions are.
I respect your opinion on this, but I disagree.
Nvida has stock clocks for cards that pull a set amount of power and give off a set amount of heat. If there is spare power and thermal overhead, Nvidia allows for higher clocks via turbo mode. The more spare power and TDP you have, the higher the turbo clocks.
On battery power, the Blade needs to stay within 100 watts of power use, so it leaves the CPU running in turbo mode, but pulls the GPU out of turbo mode and falls back to stock Nvidia frequencies. Not the power saving low power Nvidia frequencies, but the full power stock frequencies.
Check the clocks on other gaming notebooks when you pull the power. You will see 60%+ cuts to clock rates in some machines that have 50% more battery capacity.
Yes, you are correct, the Blade cannot perform at the same level on battery power. It is very close though. Close enough to not let your friends down in a multi player game when someone kicks out the power cord. Trust me, I pulled the cord during boss fights while I wrote this review and it held up.
