Question Realtek GbE latency issue on MSI MPG X570 Gaming Edge Wifi
Mar 22, 2020
4
Please forgive me if I missed any etiquette for this board, this is my first time posting
System:
Windows 10 64bit
Ryzen 7 3700x
Corsair Vengeance LPX 16GB (2 X 8GB) DDR4 3600 (XMP enabled)
ASUS GeForce RTX 2070 Super Overclocked 8G EVO GDDR6 Dual-Fan
Samsung 500GB 970 Evo NVme
Background:
Alright so this has been an issue that's been existing for maybe 5 or so days since I built my PC (despite a 2nd clean windows install and numerous driver updates). The issue itself being horrendous audio and video stutter around an hour or so after the pc has booted and persists until reboot. Not terribly consistent, but incredibly annoying during productivity or gaming
After reading multiple forums and questions similar to mine, I was recommended using LatencyMon to monitor this
My results improved considerably when I uninstalled the AMD storage controller and switched instead to the generic microsoft one (as opposed to the specific driver listed on the support page from msi) The process was storport.sys
However the next process also contributing to high latency was directx and nvlddmkm (both from nvidia) After reinstalling my video drivers (and removing them in safe mode with DDU-Display Driver Uninstaller) I happened to try disabling my LAN card and BAM all of my latency issues are solved
QUESTION:
Is there any way to fix this with a different set of drivers? I've tried two different installers from Realtek's downloads page and they both not only didn't work, but increased the latency so much that it was impossible to restart the pc, thus forcing me to power off the system.
the NIC model is Realtek 8111H as listed on MSI's specification page for the motherboard
and before anyone asks, yes I have flashed the motherboard bios and updated the latest chipset drivers
https://applescoop.com/realtek-pcie-gbe-family-controller/ ah before I forget, this guide did not help me either
System:
Windows 10 64bit
Ryzen 7 3700x
Background:
QUESTION:
Followup!
I highly recommend downloading the Realtek Ethernet Diagnostic Utility and disable both *Energy Efficient Ethernet and *Power Saving mode
I will follow up this post with another, but it seems to be mostly resolved
Please let me know if this worked for you! I will check back periodically if this issue returns
Watch the language
welcome to big dumb stupid hour where I used drivereasy to install the wrong sata drivers
DO NOT install AMD Sata Controller on the am4 platform, it will Removed
