Hi!
I just built my computer(2021-01-03).
In the process I had to remove some of the parts for troubleshooting because it didn’t post, and I had to remove the cooler and cpu to double check.
I found out that the problem was old bios and the computer is now running.
Do you all recommend to clean and reapply the thermal compound or should I wait?
idle temp 29-31°c
Whitley gaming 60-69°c
I hade a amd ryzen 5 5600x and a corsair h100x.
Sorry for my bad english.
idle temp 29-31°c
