Question Rear Mic Jack not working
Dec 8, 2018
As the title says my rear mic jack isn't working. When I plug in my mic it appears and then disappears rapidly. The front works but since my headphones are up there as well my friends can hear my Discord audio. I did a small amount of monitored travel with my computer and nothing else was damaged. It makes me think that that jack is now ruined. Any help is greatly appreciated.
What's happening: https://giphy.com/gifs/QBq2FeSWW8U6nw4grQ
Hello
Can you please try this:
Type Find and fix problems with recording sound in the Cortana search box and follow the on-screen instructions to fix the issue.
If the above doesn't work, please try uninstalling and then re-installing the latest audio driver.
If nothing works, you may want to try running the SFC /SCANNOW Command to let Windows 10 automatically find and fix any issues with the system files.
Good Luck!!
