Reccomend Workstation for Anatomical CAD, MIMICS & 3matic
minimoogle
Hi guys. I'm a Bio Med researcher at UCLA in the Biology 3D imaging labs. We're currently ramping up our computing power for the summer and fall seasons with new NSF grant $$$ and with GE's donations of new CAD scanning equipment and CT scanners. The project will use the CAD scanners to model full 3D images of skulls and tooth structure, as well as cranial and neurological patterning, and software to model and analyze the scans into manageable data that can be tested to prove a hypothesis for numerous graduate studies.
We need a workstation (or two) capable of smoothly running a program called Mimics and 3matic, both of which allow analysis and editing of the data created by the scanning tools.
Mimics has the following req's
http://biomedical.materialise.com/mimics
any multicore processor
2 GB RAM - for large datasets (> 1 GB) we recommend 8 GB RAM
ATI RADEON or NVIDIA GeForce card with 512 MB RAM
10 GB free hard disk space
Resolution of 1680x1050 or higher
Directx 10.0
and 3matic is just as intensive.
We're planning on running it a LOT harder than this and on a 30" monitor so a good GPU will probably be needed.
I was wondering if someone could cobble together a good multicore system. Perhaps the new Ivy Bridge i7 (quad or six core) build that can handle the graphics load and be smooth. 16GB of RAM is ideal, more if possible.
If possible, I would like to use a microATX form factor enclosure (was thinking Silverstones FT03) to minimize desk footprint as we need a big monitor, keyboard, mouse, and a large WACOM tablet on the same deskspace to analyze each project adequately, but if not any standard ATX motherboard will do I suppose.
Budget is about $2-3k USD per PC. Windows 7, since compatibility issues btwn the scanning tools and programs necessitate it. I have experience with building PC's and will assemble and hopefully get this thing to post, but have never built anything this high end (I built a few ~$1000 gaming systems before) and would love opinions.
I would suggest
Corsair Obsidian Series 650D $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139006&Tpk=Corsair%20650D
The SandyBridge Cpu runs alot cooler than IvyBridge
i7 990X 1,029.99 Six-Core Processor This is as good it can get, it can handle anything you throw at it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115079
ASUS Rampage III Gene $229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131658
GPU Sapphire 7870 Can support up to 6 monitor per graphics card $359.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102983
24Gb Mushkin Silverline $159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226262
CORSAIR Professional Series Gold AX1200 $299.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014&Tpk=corsair%201200w
1tb Caviar Black 119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
LITE-ON Black 18X DVD-ROM $18.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106276
This can handle anything.
Total: $2218.93 (Shipping&Handling and Tax and Mail in Rebate is not included)
Monitor Dell UltraSharp U3011 30"
1,299.99
Grand Total 3518.92
REMEMBER: Shipping&Handling and Tax and Mail in Rebate is NOT included
I didn't go with a too high end graphics card because it does not require a lot of graphics processing more of the CPU
Not much difference in performance but still works out. On the recommended config is a ATI Radeon or Nvidia GTX. I kind of agree but I'm going to go with following what it recommends.
Obviously, but you need support for multiple monitors and that is what the requirement said.
