Recommended fan curve for an EVGA GeForce GTX 980 Ti SC+?
TexasTech
13
My 980 ti, during normal gaming applications, will max out at 79-81 Celsius. While i know this isn't horrible it is still too hot for my liking. I downloaded msi afterburner and the stock fan curve seems like it would be too loud, since the fans run at 80% when the card hits 80 c. Any recommendations? I personally am not too big on loud fans though, even though my headphones are closed back.
Well if you don't like your GPU above 80 C and you don't like the noise of your GPU getting cooler than 80 C, then your only option left is to clock it down so it doesn't get as hot.
