Question Red CPU LED on the motherboard ?
i think your mb must be dead
I can't think of anything else wrong, only by testing one by one will you find what's wrong.
Yep, thats what I thought.
If I'm not wrong, RAM should trigger its own light, as well as GPU.
Only thing is SSD, but I haven't touched it before the problem appeared, so it must be the motherboard.
Probably will go today/tomorrow and get the MSI B760 Tomahawk.
-400€, for just trying to fix a buzzing sound🥲(new case, new cooling, new mobo)
Bought a new motherboard yesterday.
MSI MAG B760 Tomahawk.
Installed it, and it works!
Its quiet as hell, quieter than my old AIO even was when it was new (Case is open, yet I don't hear the PC working😍)
I still don't actually got a clue why my old mobo died, so if you guys might have an idea about that, I will gladly listen, so I don't cause damage in any way to the new motherboard.
only thing i can think of damaging was tilting it could have caused something to short the motherboard especially if the machine was on if something wasnt plugged right anythings possible.
as for your aio what orientation was it mounted in the top or front. ?.
The radiator was on top
think radiator was on way out then.
as for the damage to the board movement may have flexed the board as well.
these cpus are known to become warped over time. least i9 are the heat generated isnt greatest hence the lga 1700 bracket.
https://www.amazon.co.uk/Thermalrig...8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
which ive used even though intel says it would void warrenty even with there own stupid cpus are bending themselves lol.
