REINSTALL - 2 PROBLEMS - REACTIVATE & EXTENDED PARTITION
dw
99
Archived from groups: microsoft.public.windowsxp.general (More info?)
I reinstalled XPsp1, by deleting the partition it was originally installed
on, recreating the partition, and reformatting the partition, then
reinstalling via Windows Setup.
Now when I try to get Windows Updates it wants me to reactivate. My system
has not changed so why do I have to reactivate?
ALSO
I recreated the partition, and reformatted it, during XPsp1 sestup, and then
reinstalled XPsp1 - now, when I view the disks via Computer Management it
shows:
C: (the recreated/reformatted/with reinstalled XPsp1 partition) as
Extended Partition - Logical Drive (Boot)
D: (data) as Primary Partition (System)
E: (backups) as Primary Partition
So, do I have to start over again? (I began this little adventure back on
Thursday evening - I think I have stuffed up everything I could have so far!
Thanks for any assistance.
DeeDee
The activation information was stored on the drive that you reformatted.
If it has been over 120 days since the last activation, you should be able
to activate over the Internet.
If not then just activate over the phone.
The names commonly used for partitions containing the startup and operating
system files are system and boot partitions, respectively.
D has the startup files for XP. It must be the active partition.
Is it the first partition? It doesn't make any difference, just curious.
Did you reletter the drives?
What size is C?
Ron Sommer
"dw" <deedee@yahoo.com> wrote in message
news:ewCn98EsFHA.904@tk2msftngp13.phx.gbl...
> system
> ALSO
> then
> shows:
> far!
> DeeDee
Thank you so much for responding Ron.
I activated XP yesterday! Then reinstalled. So will have to reactivate
over the phone - hope they do this 24/7. I have to get this finished!
The c: (1st) extended partition/logical drive has XP Pro & Programs
installed on it.
The d: (2nd) partition/primary drive is just for data
The e: (3rd) partition/primary drive is for backups.
None of the drives are marked as "active".
So, no D is not the first partition. And I didn't reletter the drives. c:
is 20gig
It sounds like I do need to reinstall. Which is fine if I do. I just want
to get it finished and get it right finally. (I hope!)
In which case I would be doing clean install of XPsp1 by:
deleting ALL existing partitions
create first partition and reformat using XP setup
install XPsp1 on first partition
once XP is installed and loaded, create and format the remaining partitions
from within windows using XP
and, I need to nominate c as the "active" partition?
Does that sound right?
Thanks for your help and any further assistance you can offer.
DeeDee
> What size is C?
> Ron Sommer
> > system
> > ALSO
> > then
> > shows:
> > far!
> > DeeDee
You don't have to reinstall, but now would be the best time to straighten up
the partitions.
D has the boot files, so if you deleted D, then XP won't boot.
Boot to the install CD.
Cancel the install and go into maintenance.
Delete the first partition, create a primary partition, format and make it
active, install XP.
There is no need to delete the other partitions.
Ron Sommer
"DeeDee" <DeeDee@discussions.microsoft.com> wrote in message
news:36C0E878-CCD7-410F-ABF8-9DCC7E707593@microsoft.com...
> installed on it.
> c:
> is 20gig
> want
> partitions
> DeeDee
>> able
>> operating
>> What size is C?
>> Ron Sommer
>> >installed
>> > system
>> > ALSO
>> > then
>> > it
>> > shows:
>> > on
>> > far!
>> > DeeDee
Just one other point about Partitioning with the XP CD. Partitions are
generally initialized by a system boot. If you use the XP CD to change
the structures, I would exit the Install process after changes and boot
the machine again. This ensures that partitions are as you expect and
that Drive letters are assigned correctly. This can help you avoid the
end result of XP being installed on Drive D:, E:....In other words make
your changes and restart the installation process to verify that it is in
fact the way you want - those 5-7 minutes are worth it.
"Ron Sommer" <rsommer@nospam.ktis.net> wrote in message
news:%23dUYGvHsFHA.1132@TK2MSFTNGP10.phx.gbl...
> up the partitions.
> active, install XP.
> Ron Sommer
>> installed on it.
>> c:
>> is 20gig
>> want
>> partitions
>> DeeDee
>>> able
>>> operating
>>> curious.
>>> What size is C?
>>> Ron Sommer
>>> >installed
>>> > system
>>> > ALSO
>>> > and
>>> > then
>>> > it
>>> > shows:
>>> > back on
>>> > so
>>> > far!
>>> > DeeDee
OK, thanks again, and for such a quick response. Agree, I definitely want
to get things right now, rather than later. Will try your suggestions
immediately.
DeeDee
news:#dUYGvHsFHA.1132@TK2MSFTNGP10.phx.gbl...
up
> the partitions.
> active, install XP.
> Ron Sommer
> > installed on it.
> > c:
> > is 20gig
> > want
> > partitions
> > DeeDee
reformatted.
> >> able
> >> operating
curious.
> >> What size is C?
> >> Ron Sommer
> >> >installed
> >> > system
> >> > ALSO
and
> >> > then
Management
> >> > it
> >> > shows:
back
> >> > on
so
> >> > far!
> >> > DeeDee
The reactivation requirement is normal if clean installed.
There's something you're not telling us regarding the partition's previous
condition, and windows boot partition location.
system
> ALSO
then
> shows:
far!
> DeeDee
Thanks to all for help offered.
I have repartitioned, reformatted, reinstalled. Whilst it looks OK now. I
wasn't given any opportunity to mark the partition as Active from within
setup - and wasn't overly concerned as I thought I would be able to do this
from Computer Management - however, I am only able to mark either the 2nd or
3rd partitions as active, when I try to do so for the 1st partition - the
option is dimmed out. Is this an issue now, or in the future?
Thanks again.
DeeDee
"R. McCarty" <PcEngWork-NoSpam_@mindspring.com> wrote in message
news:ucAOa0HsFHA.2348@tk2msftngp13.phx.gbl...
straighten
> > up the partitions.
it
> > active, install XP.
> > Ron Sommer
reactivate
> >> installed on it.
> >> c:
> >> is 20gig
> >> want
> >> partitions
> >> DeeDee
reformatted.
> >>> able
> >>> operating
> >>> curious.
> >>> What size is C?
> >>> Ron Sommer
> >>> >installed
> >>> > system
> >>> > ALSO
> >>> > and
> >>> > then
Management
> >>> > it
> >>> > shows:
as
> >>> > back on
> >>> > so
> >>> > far!
> >>> > DeeDee
Mark as Active is dimmed out because that partition is a already active.
Ron Sommer
"dw" <dd_words@yahoo.com.au> wrote in message
news:u89NtPQsFHA.332@tk2msftngp13.phx.gbl...
> I
> this
> or
> Thanks again.
> DeeDee
snipped
