remote power / laptop
G
Guest
Guest
Archived from groups: comp.sys.laptops (More info?)
Help!!
We need to be able to power the laptop (DELL Latitude) externally, by
clicking on some switch on the outside panel.
Let me explain: The laptop is used to control the internal devices.
The goal is to somehow bring out the power switch to the outside of
the device so that the user can switch the power to the entire system,
including the notebook, with one switch.
I have searched everywhere but can't find any solid solution. I am
thinking of using the expansion port, I found the pin outs, but can't
figure out what pins will simulate the power-switch press.
HELP !!
Thanks,
Oleg
G
Guest
Guest
Well, you could wire an external switch to the power switch, though
I'd be more inclined to muck around with a Port Replicator or Docking
Station. You could probably do something with Wake-on-LAN and a
remote power-down daemon, but it kinda depends on what you're doing.
[If you are sealing a laptop inside a box, make sure there's some
forced ventilation, so it doesn't melt down...]
G
Guest
Guest
oleg wrote:
> Help!!
> HELP !!
> Thanks,
> Oleg
I think you should look at the power button itself. On digital cameras
I can trip the shutter with a simply make-break switch soldered across
the appropriate terminals and power-on with another switch. The same
should apply to the notebook power switch. I think you will be able to
not only start the notebook, but also intiate shutdown and emergency
shutdown (holding the power button down for several seconds by external
mechanical switches across the appropriate power button terminals.
Since you don't want to sacrifice the notebook doing the research, you
might get your electronics guru involved (that's the person who has the
voltmeter).
Q
