Removing Color Blocks from Behind Icon Labels
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Under the icons on my desktop are text labels. I use two Windows XP
computers. One of them displays a color background behind these text labels
and the other one doesn't. I like not having a color background behind these
labels. How do I get rid of it? (I know how to change the color, but
haven't found a way to turn it off or make it transparent. Yet, it must be
possible, because my other computer is that way.)
Thanks for the help.
Right click My Computer and select Properties, Advances, Performance (Settings). Uncheck Use drop shadows............
Note: If you have Active Desktop enabled, this setting will not make a differene.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"Wade" <Wade@discussions.microsoft.com> wrote in message news:1C450F3B-8113-42DB-A074-6D5994A0A50F@microsoft.com...
"Doug Knox MS-MVP" <dknox@mvps.org> wrote in
news:ukPhxC7lFHA.1204@TK2MSFTNGP12.phx.gbl:
> differene.
Mine is backwards. By checking 'Use drop shadows for icon labels on the
desktop' the text backgrounds for my desktop icons dissappeared. Any
thoughts on why this is backwards?
Nope, I've never seen it work in reverse!
"John Smithe" <JS@Huh.Wha> wrote in message news:Xns96A82945A7816DQ1V55H078NX3AGH5MJX@207.46.248.16...
>> differene.
> Windows XP
> these text labels
> color, but
> Yet, it must be
Open system properties, go to Advnaced, click the Performance Settings
button, and ensure that "Adjust for best apperance" is checked, if it
is alredy cheded, check a diffrant setting, click applie, and then set
it back to best apareance.
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Customize-Removing-Color-Blocks-Icon-Labels-ftopict403850.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1337666
