Removing Side Rails For Painting???
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi Guys,
What have you found is the easiest and least damaging way to remove
side rails from your older pins in order to prep for repainting?
I know some of you just paint around the side rails, but I would like
to remove mine in order to repaint the entire cabinet.
I actually have several cabinets that will be repainted. These are late
'70s and early '80s Ballys.
Thanks so much!
Tim
G
Guest
Guest
It's pretty amazing what you can find when you remember to google, lol.
Sorry for the duplicate question.
Tim
G
Guest
Guest
I use needle nose pliers, small nail head pullers, shim stock wood to
lever against and anything handy that works. Some damage around the
nailheads is going to happen, I use auto body hammers and dowels to
reform any significant damage.
K2
G
Guest
Guest
I use a puddy knife to get under metal, then I use a small pair of vice
grips and grab the nail inbetween the teeth and twist to left
(counterclockwise) to remove nail. Im able to save all twist nails;
buffem up and good to go...
G
Guest
Guest
I'm all for thrift and saving, but I find some of the edges twist a little
bit so I do the same but spend the $3 on new nails.
GRY
"Grojohn" <carniello@comcast.net> wrote in message
news:1119581838.541472.132990@g14g2000cwa.googlegroups.com...
