Question Repair System32 on computer ?
accidentally deleted it without knowing it was the system files
Reinstall Windows.
There is no "fix" for a missing /System32/ folder.
(you will need a different, working, PC and a 8GB flash drive)
Reactions: Phillip Corcoran
Reinstall Windows.
possible to fix with the reset or cmd?
LOL
Deleting system32 folder?
System Protection Service should have prevented that.
Unless you had it turned off. Did you?
If System Restore was not turned off, then use it to restore to time before your modifications.
https://www.windowscentral.com/how-use-system-restore-windows-10
If you can get into windows then do repair install.
https://www.tomshardware.com/how-to/fix-windows-10-repair-install
If you can not, then boot from windows installation media and do clean install.
https://www.tomshardware.com/news/how-to-do-clean-installation-windows-10,36160.html
But why CMD commands wil not work to repair the system?
(chkdsk command, sfc /scannow)
(sorry, i don`t know anyting about it)
Simple. You deleted a boatload of files that need to be replaced. To do this requires the source of those files. Chkdsk, SFC etc. do NOT provide this source of the files. In other news, by deleting /SYSTEM32 you also deleted the registry. This requires a full wipe and reinstall of everything.
Ok, understandable!
Have a nice weekend, sir!
