So I need to replace my motherboard (since the one I own currently is very old and doesn't support newer GPUs) and my current CPU, i7 2600, has the socket LGA 1155. The cheapest motherboard for that socket (as far as I know) is around 130-140 euros. Is it worth it to upgrade my motherboard to for example LGA 1151 and upgrade my cpu, or is it better to just buy the motherboard and keep the CPU? And if I should replace both my motherboard and my CPU, which CPU is cheap (under 100 euros) and will not make a huge impact on my performance?
Thanks in advance.
Thanks in advance.
