Hello,
I have an HP Pavilion 500-037c Desktop PC (h5q07aar#aba) that has a dead motherboard. I am unsure of whether or not that also means that my A10 processor chip is done. My questions are:
1) Can you suggest an alternative MB that will be a drop in fit in the case that I have with all of the other stock hardware? Including the A10 chip which I want to reuse.
2) Is there an easy way to test the chip prior to getting a new MB? and if not, what would happen if the chip is dead and I put it into the new MB?
Considerations: I am not using this computer for gaming or anything intensive. It is solely for browsing internet, emails, and the odd youtube video. Don't want to break the bank and get something amazing and don't need to worry about future upgrades since this is a secondary computer not my main one. I just can't justify getting a whole new computer for what I use it for.
Specs:
http://
Motherboard:
MS-7778 (JasmineR)
Manufacturer: MSI
Form factor: uATX: 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Chipset: AMD A75 FCH
Memory sockets: 4 x DDR3
Front side bus speeds: 4 lanes, 5 GT/s per lane
Processor socket: FM2
Expansion Slots:
1 PCI Express x16 (Gen2.0)
3 PCI Express x1 (Gen2.0)
1 half-length mini card
Processor:
AMD A10-5700
TDP: 65W
Operating speed: 3.4 GHz (up to 4.0 GHz turbo)
Number of cores: 4
Socket: FM2
Memory:
12 GB
Speed: PC3-12800 MB/sec
Type: DDR3-1600
Graphics/sound/networking:
Onboard
Harddrive:
2TB Sata, 7200 RPM
Tower:
Height: 36.7 cm (14.48 inches) unpacked
Width: 17.5 cm (6.91 inches) unpacked
Length: 38.9 cm (15.35 inches) unpacked
Power Supply
300W (I have others)
Specs:
http://
Motherboard:
MS-7778 (JasmineR)
Manufacturer: MSI
Expansion Slots:
Processor:
AMD A10-5700
TDP: 65W
Number of cores: 4
Socket: FM2
Memory:
12 GB
Type: DDR3-1600
Onboard
Harddrive:
2TB Sata, 7200 RPM
Tower:
Power Supply
