max 290 mm ATX Graphics Capability
Oh man thank you for the advise. I'll check that out. As you said, maybe I should be aiming to a lower graphics card... but my gtx 970 still works great, but I miss a bit more of power for current games on the market.
I'll have a look on gtx-1070.
thanks! I'll let you know what I did if useful for anyone else .
How many pins does it use?? Because my PSU comes with a double 6-pin connector..You dont need to change the power supply for upto ~180 watts GPU.
you can use RTX 2060 super in that system ,
Hold up on that. Before recommending any GPU for use with your current power supply we need to know the PSU exact model number. Without knowing how many amps it can deliver on the +12 volt it's impossible to gauge its capabilities. Since MSI provides no information that I could find detailing the PSU specs we need to see a picture of the label on the PSU or at the very least what the amp rating is for +12 volt.How many pins does it use?? Because my PSU comes with a double 6-pin connector..
thanks
thanks
Why i suggested the SFX psu with ATX bracket.and dont upgrade the PSU , there is ZERO place for cables inside that case , it wont fit no matter how you try .. unless you cut the cables and mod them.
I think I rather go for a Air Cooler. My current CPU cooler dimension are 10mm diametre and 8,5mm height, but there is enough space for a bigger (or taller) cooler.
wow looks great, but... the question is, how much?!?
Oh I think it should be one with low power consumption, bear in mind my PSU limitation! 😀
