Would the MSI Frozr L fit in my case? Would it be valid for my cpu?
thanks
It looks great, for little money ... In CoolMod shop, costs 33,95€!! It's reasonably cheap!This should work if the 145mm tall is what the case really can take (it's 125mm tall),
https://es.pcpartpicker.com/product/TnJtt6/cryorig-m9-plus-484-cfm-cpu-cooler-m9-plus
not really for heavy overclocking but should do fine with the stock 4790K.
Hello ,
There are Things to consider ,
1- The side 120 fan above the motherboard is 25mm ....
Do you mean the red back fan in the case? I'm not an expert on this as you can see...haha
So, if I understood conrrectly: I can't put a vertical CPU fan taller than 120mm, can I?
What do you think is better vertical or horizontal CPU fan? The one I have is the stock CPU fan from MSI which is very similar to stock intel fans, and it is horizontal position (to the moherboard). I guess it has something to be with drilled side panel..
My budget is up to 50€ but the less money I use the better 😀
thank you!
There are two fans in your case , one red back 92 and one on the door 120 .. right ?
www.back2gaming.com
ohh know I see why you thought there was a 120mm side fan... because the nightblade Z97 has one... look this webside at the end of the page you can see the differences.
MSI Nightblade Review
The MSI Nightblade is a good product but at its price point you're better of building your own ITX system with a BitFenix Phenom. Read our full thoughts on the MSI Nightblade and why MSI needs to decide whether they're selling a case or a half-built system in this #B2G review.www.back2gaming.com
Cryorig makes good coolers, since when are those low grade?
He can get the Cryorig for €20 less, that is quite the amount and it will still cool that 4790K fine with the capability of cooling 130watt TDP.
It's up to him, think he just should read some reviews for his own peace of mind.
Don't know what the shipping is there.In CoolMod shop, costs 33,95€!! It's reasonably cheap!
