Replacing 120mm fans in Antec 1200 case?
kompulsive
Is anyone out there familiar with this process? Two of the front 120mm fans in my 1200 case are dead and I need to replace them. The problem is, I don't see where to disconnect the existing fans from. I've looked at the manual and the mechanical drawings and I can't figure it out. Do the wires trail back to molex connectors or what?
i'm getting it figured out as we speak. the fans that i'm installing just have the 3 pin connectors that go directly into my motherboard so i'm ripping out the adjustor knobs on the stock fans as well. it is unfortunate that there isn't a modular way to do this so you can replace them on the fly, such as putting the connection point in the actual fan housing rather than deep inside of the case via molex connector.
The fan headers are provided on the motherboard so that you can control/monitor the speed via settings in the BIOS. Your manual will explain this in detail.
Alternately, you can connect the fans directly to the PSU via 4-pin Molex connectors. Multiple fans can be 'daisy-chained' and then plugged into a single 4-pin Molex connector.
Good luck!
Latest posts
