Just thought I'd follow up on this. I did get it and I installed it. Installation isn't the easiest since I couldn't poke the pins back through the holes with the old fan. Instead I took pliers, crushed the ends, and used toenail clippers to cut the plastic pins off.
It looked like they used a really cheap thermal pad on the die and it was only about half covered. I applied some Arctic Silver III and put the new fan on. To get it on though is a bit cumbersome since the holes don't align perfectly. You kind of have to put one pin in first and then bend the other plastic pin into place.
All in all, it's about 15 minutes of work. A bit more taking the motherboard out and putting it back in. My temps dropped a few degrees as did the noise. If you like pretty colors you might like the way this thing looks too.
