Request Help With Ans
wiznai
7
I cannot find an answer to my problem of : every time i restart my computer laptop a message comes up saying mswinsck.ocx or component liked to this did not load, i have downloaded some links but no answer just yet, My laptop driver and config tools say nothing is missing, I now need help to over come this problem please.
Akashdeep
938
Follow the steps:
1. Click Start, type “command” in the start search box.
2. From the program list right click cmd.exe, and click on Run as administrator.
3. Type “regsvr32.exe mswinsck.ocx” Without quotes and hit Enter.
Hope this will help you.
wiznai
7
wiznai
7
wiznai
7
Thanks Akashdeep : But i had all ready tried this this solution and a post comes back as.
RegSvr32 (Posts)
The mduule"mswinsck.ocx" faild to Load
Make sure the binary is stored at the speccified path or debug it to check for prblems with binary or dependent.DLL files.
The specified module could no be found.
So i need help as where to go from here the only DLL that comes near this is a mswsock.dll which is a application extension in my system32 folder.
wiznai
7
It is not in the folder, I have tried a couple of places that say i have to register a download but did not work, and another couple of downloads that my antivirus and malware working, so if you Akashdeep or anyone else can come up with an answer it will be much appreciated.
Thanks ahead of time :)
wiznai
7
Akashdeep: Hi downloaded the file and followed it to the letter after 3 Minutes the file stops and says it can not load, and yes i use visual Basic and now my laptop is slower also, I am really stumped as i seem to be going around i circles.
wiznai
7
